p-pumping the 89 have questions
i have a p-pump i would like to put on my 89 i know injectors turbo fule lines exc is needed but what eles would i need to do ? thanks
Timing case, timing case cover, injector pump gear, injector pump brackets, throttle linkage setup, fuel inlet line(s), fuel return line and a nice lift pump to back it all up.
Youll have to take out the cam, so while you got it out, at the min get your cam gear either welded or bolted on. If you got the extra money get aftermarket cam that already has a bolt on gear.
I think thats about everything. Im in the middle of gathering parts for the same swap as we speak.
how come he has to take the cam out... i just used a gear puller and it came right off. to put it back on use a lil heat and it will go right on...
thats how i did mine.
Vitamin C
03-26-2007 09:59 AM
Dodgezilla
11-16-2005 07:08 PM
