P Pump question
P Pump question
I have a 1992 Injection Pump Cummins 6BT 5.9 L 190 HP 810 from a school bus. Can this be installed on my 93. You can see it in my classified ad.
Rebuilt Injection Pump Cummins 6BT 5.9 L 190HP Cummins # 3921777, 3921777RX 3919090, 0 402 736 810 + $1000.00 core 0402736810 $1695.00
The pump came off of a 92 bus.
might wanna double check, but i think you may need the cam out of that motor as well. i could be wrong but that's what i've read from others doing a p-pump swap. of course you may know, you'll need high pressure lines, pump gear, pump mounting bracket, timing cover, shutdown solenoid functionality, throttle cable hook-up and oil lines for internal pump lubrication.
I'm going to be p-pumping my truck here pretty soon an was thinking of getting a turbo too, do u guys think the he351 would be good with a p-pump or should I just go ahead an get a phatshaft 62 or bigger. My pump is a 215hp pump if that helps
get something bigger than a he351, it would be a waste of money and time.
