P-7100 Pump on a first gen.?
Check this link Cowboy Customs is in the process of his switch to the p-pump
https://www.dieseltruckresource.com/...d.php?t=144736
Ryan
Ryan
U will need a pump p timing cover,pump lines and p pump injectors and oil lines to lube the afc and bottom end of the pump. move the fuel filter to the back of the intake plan. plus a piston lift pump. Im sure I left out some suff!
Costs a mint.....
Plus, the VE has proven to go beyond the capacity of the drivetrain, so the P-pump would be an expensive add on for the testerone- deprived to make up the slack.
400 streetable HP is achievable wtih the right combination of fuel and airflow improvements.
Daniel
Daniel
alexschultz1
01-10-2007 11:32 PM
ataboy9026
01-19-2006 10:51 PM
