Overload Spring Stops
Old 08-18-2012 | 11:24 PM
1972RedNeck's Avatar
I would like to install some overload springs on my '93. I use it as my tow vehicle and it squats real bad when I put any load at all on it. I have springs, I just need the over load brackets. It appears to me that the frame is already pre-drilled. It has 3 holes in the area the auxiliary spring perch should be mounted.
Where can i get these perches? Does somebody have a part number? Do they have a rubber insert like the newer ones?
Old 08-19-2012 | 12:03 AM
It would be much easier to buy a new set of air bags for the rear of the truck...
http://www.amazon.com/57215-LoadLift...I18X3YVSPZ15Z9
The truck will ride much nicer as well if you keep them aired up just enough to take the weight off of the springs.
Next modification I'm doing for my truck.
Old 08-19-2012 | 02:05 AM
jimbo486's Avatar
I've got some if you decide to stick with the factory overloads. I'll have to see if I can dig them up from out of my parts box. They need new inserts if those are obtainable.
Old 08-19-2012 | 09:07 AM
stoneagemaxx's Avatar
if the op deciedes he doesent want the overload perches shoot me a pm thx
braap736
02-18-2011 04:46 PM
ticki2
01-05-2011 11:16 AM
sdsaw
04-21-2007 11:52 PM
petei
08-05-2004 04:50 AM
petei
07-28-2004 10:00 PM
Quick Reply: Overload Spring Stops
