Overdrive Solenoid
Old 11-02-2011 | 10:28 PM
trekkie9876's Avatar
Overdrive Solenoid
A couple months ago I bought a 1993 D250 with an automatic transmission. After a couple weeks it started shifting in and out of overdrive driving down the highway. After doing some research I bypassed the TPS with a potentiometer. This did not fix the problem.
I ended up taking the truck to my local transmission shop where they said it was the overdrive solenoid. They replaced the solenoid and said I was good to go.
A couple days later when I got it out on the highway, it started shifting in and out of overdrive again. Back to the shop. They looked into it and said the overdrive solenoid had shorted out and needed replaced again. They looked over the transmission wiring harness and could not find anything that would have shorted it out.
Does anyone know where else I should look to find out what is shorting out the overdrive solenoid?
Thanks for your help.
-Andrew
Old 11-02-2011 | 10:53 PM
tech-eh's Avatar
check be hind the dash switch something rubbing or the switch it self there is a sharp steel guide member back there
Old 11-03-2011 | 10:07 AM
d22019's Avatar
You might want to by pass the temp sensor that is in the hot line. Mine did the same thing and it turned out the sensor was bad causing it to shift in and out. I tied the wire together and installed a new od solenoid and so far so good.
dodgediesel
04-15-2010 10:00 PM
vanman59
03-24-2009 06:58 PM
dragstriptrash
05-03-2008 03:55 PM
maxpower
09-03-2007 06:46 PM
daystar
02-19-2004 07:21 PM
