overcharging battery
Old 01-30-2009 | 01:51 PM
Emoo60's Avatar
I have a quick question, my alternator has been overcharging the battery which eventually kills it. I am on my second battery and my volt meter still reads between 14,16 volts. I have replaced the external regulator and grounded it. what am i missing? This is on my 79 dump I repowered with an early 91 drive train. I use this truck to plow snow so I know that can be hard on a battery too. Any ideas would be appreciated. thanks
Evan
Old 01-30-2009 | 02:39 PM
John Faughn's Avatar
Many of the older voltage regulators [ one with metal cover that could screw off ] had points , were adjustable .
What kind of alt. is it ? , How many amps ?
Old 01-30-2009 | 07:05 PM
14racing's Avatar
Is that the voltmeter in the dash or are you taking a reading at the battery? I'm not too convinced the factory ones are that accurate.
Old 01-30-2009 | 11:45 PM
Emoo60's Avatar
the alt. is the one that came with the cummins engine. I"ll get a volt meter and check the battery. thanks.
Old 01-30-2009 | 11:51 PM
14racing's Avatar
Also the voltmeter in my dash seems to read a lot higher when it is really cold out, say 10 or colder. I've never checked it at battery when it does this but it hasn't caused me any trouble.
Old 01-30-2009 | 11:59 PM
rebal's Avatar
get a new USA made v reg from napa NOT there cheepo one that is your problem the reg. will look just like the one used in 79 but get it for the 91 cummins
thsboss99
12-28-2017 11:19 PM
vcoyle
23
03-15-2011 07:15 PM
jwb600
07-19-2009 09:06 PM
dieseldave24v
02-17-2008 05:28 PM
alottalights
12-21-2004 10:54 PM
