Our Factory Turbo Specs?
Does anyone have reference to the exact facory specs of our turbo? I am looking for inducer/exducer size and trim for compresssor as well as wheel size and trim for the turbine section. Also the A/R for the comp and turbine would be great. I want to use my original turbo for a different application so I need to know the exact sizes. Thanks.
I did a net search for Holset turbos a while back and found something like you are needing. You might try that. I couldnt get any responses now though.
You might want to try this site
http://www.holset.co.uk/files/4_4_1-...%20manuals.php
You will have to allow pop ups if you block them.
It is a zipped pdf of 3.89mb for the H1C
Hope this helps
Michael
Hope this helps
Michael
I think the turbos on all 1st gens use the same turbine wheel. I'm not sure on the inducer size, but I believe the exducer is 57mm. The inducer is probably around 65mm. The 18cm and 21cm exhaust housings are a pretty big A/R. Unfortunately Holset doesn't give an A/R for their compressor or turbine housings.
Non-IC trucks have the "baby H1C" with 3" compressor inlet and 2" outlet. The compressor wheel should have a 50mm inducer and an 83mm exducer (I think).
IC trucks have a 54mm inducer/83mm exducer compressor wheel.
bobinyelm
20
03-04-2010 11:11 AM
chw
12-22-2006 11:21 AM
06RAMCTD
0
12-19-2006 04:15 PM
