One ton trucks turbo bigger then 250 ??
This has probably been brought up in the past but.... on the HTT website heres what it says for the stage 2 H1C upgrade compressor kit...
STAGE II 325 hp UPGRADE COMPRESSOR HOUSING AND 58mm WHEEL - 91-94 DODGE/CUMMINS
$225.00 (housing and wheel only)
For H1C, WH1C model Holset turbos
This upgrade will allow more air to meet the demands of minor fuel and timing changes made to your truck turbo. This wheel is the large 8-blade wheel used in many WH1E turbos.
This housing and wheel mounts to your stock 12 valve 1991-1994 (It only bolts directly to the 91 trucks that came equipped with air-to-air charge air cooler.) Your stock compressor wheel measures 56mm unless your truck is a one-ton. This upgrade wheel measures 58mm.
Just wonderin... , Brandon
From what I have seen posted over the years the 93 duallys had a bigger intake wheel on them. That was dually only.
Mine did when I got it. It didn't stay on the truck long. It had as much play in and out on the shaft as it did side to side.
