One ton tailgate light measurements....
Old 10-25-2014 | 12:44 AM
OK as requested here are the pics, and measurements I took off a 1992 Cummins D350 reg cab dually tailgate. The tailgate was damaged, but in great shape.
So if you want to install lights in the correct location, here are all the pics, and measurements you will need o make it look factory correct.
Old 10-25-2014 | 12:51 AM
Measurements for the light mounting is a .865" hole in the middle, with an outer spacing of the screws set at 3".
Old 10-25-2014 | 12:56 AM
You can see the hole with the small body plug right under neath it. That is the dead center light. The center of that light is set at the exact middle of the tailgate.
Old 10-25-2014 | 12:58 AM
And the hole, and notch required for the wiring to pass through. This is on the LH side of the tailgate.
Hope this helps.
Old 10-25-2014 | 01:05 AM
Guess just in case these photos disappear there should be some hard text measurements.
There are 5 lights. The middle of the center light is placed in the exact center of the tailgate. Then the next two lights, to the left and right of the center light are placed 7.5" center to center.
The final two lights are placed 22" center to center off the last two that were installed. So about 29.5" center to center off the 1st light.
Old 10-25-2014 | 01:51 AM
Jim Lane's Avatar
Mr T-Cow
That was a beautiful LE tailgate, how did it get hit from the inside out?
Old 10-25-2014 | 02:24 AM
Originally Posted by Jim Lane
Mr T-Cow
That was probably one of the nicest tailgates I had ever seen! It was up when the old guy pulled out from his 5th wheel trailer...DOOOH!
Old 10-25-2014 | 08:07 AM
Jim Lane's Avatar
Wow..
That hurts about as bad as backing up with your door open and snagging a fire hydrant.
Old 10-26-2014 | 08:44 AM
69HemiGTX's Avatar
TC, thanks to your hard work, I came up with this.
Attached Thumbnails One ton tailgate light measurements....-tailgate-light-spacing1.jpg
Old 10-26-2014 | 02:16 PM
NE frmhnd's Avatar
You just gave me an idea for more LED signals.
Old 10-27-2014 | 10:26 PM
That looks perfect! Thanks for doing up that schematic!
Old 11-01-2017 | 12:38 AM
I got another one done.....
https://web.archive.org/web/20171101...ements-319739/
bigragu (11-01-2017)
bridleman
02-02-2009 11:10 PM
blake2500
02-04-2008 11:28 PM
The Roamer
12-15-2003 08:40 PM
dealseeker
24
12-18-2002 11:39 AM
dhe9
10-28-2002 05:57 PM
