Ok, trashed my H1C...Is there a cross reference for turbos?
I would like to get a replacement for my H1C....but I want it to be bolt-in...Does anyone have a listing of what will bolt in place for the 91.5 IC 5.9? Ie...found several Garret, couple of Holset's, etc......
Thanks!
Thanks!
HX-35 or WH1C or another H1C. You can use your exhaust housing over (probably the 21cm lag master, so you'll probably want to get rid of that door stop for a better option) or if its trashed you can use the wastegated housing that would come on a stock hx-35 or WH1C, to do that you'll have to move the down pipe back about an inch (I cut an inch out of mine).
Check out http://www.htturbo.com/ if your looking for new.
air filter collapsed sending a lot through the impeller ... here's the aftermath.
![](http://img.photobucket.com/albums/v256/eyoung429/sunday002.jpg)
see the nice shiney ring around the impeller? I have a LOT of clearance now!!!
eyoung429- look around and see if you can find a used hx-35. they can be had for less than $300. look in the classifieds here. you could possibly get a used h1c for very cheap but the hx-35 would be a nice upgrade.
chugger
11-19-2009 04:45 PM
horsinaround
03-03-2009 04:33 AM
kokalit
0
05-26-2008 12:12 AM
