oil pressure
oil pressure
whats the normal operation range on the gauge for your oil pressure? mine used to be on the upper part of the gauge around the second or third line, and now it will either sit on or just barely past the first line. i need an oil change soon and i think my crank case tubes clogged so im going to blow that out as well. am i in trouble or is this normal???
The pressure sending unit (and gauge) is a known problem on these engines. Best to check your pressure with a "good" mechanical gauge before you get too excited. It the pressure is good, then replace the sending unit.
Location: In Oroville, Ca., same house for past 46 yrs!
...also note that if your at the end of your oil change interval you could have some fuel dilution issues as well which 'thin out' the oil and lower the pressure.
just a thought to consider.
Even with a new/good sending unit, my stock guage reads on the low side. esspecially at idle however, I installed an aftermarket guage to ease my mind. At op. temp and idle I get 25 psi, highway speed is 55-60psi
ok, this thread was as close to answering my question but.................
on the 2nd gen at idle after complete warm up, is it normal for the factory oil gauge to register between 0-40? Under normal hwy driving it's right in the middle @ 40psi or slightly greater. The reason I ask is that I just installed an oil bypass system and want to make sure "too much isn't going thru the bypass" thus causing low oil psi for the engine. No CEL or low oil warning lights. thanks.
My .02
yes, I agree, but I'm kind of at the point of gauge overload. I'm just trying to get an idea or range of sufficient oil psi operation and make sure the oil bypass is not "bypassing" too much thus filling the upper head w/oil. thanks for the info.
HOT summer engine, 700 rpm, 18-20 psi, Highway, 2000 rpm 40 psi
cold engine anytime 40 idle and over 60 with any throttle.
Stock gauge does all kind of odd things.
GlennRMK
05-24-2007 10:46 PM
Power Ram 250 C
02-20-2007 11:08 AM
streetsmoker
02-22-2006 06:47 PM
bigragu
01-24-2006 11:16 AM
CIN'S DODGE
16
12-05-2005 04:14 PM
