oil pan torque specs
Apparently the search doesnt work cuz there was a post about this just a few days ago....anyway, I need the torque specs for the engine oil pan and the tranny oil pan (3 speed 727). thx
Why arent these posted somewhere permanently?
From 91 FSM
Oil pan bolts - 18ft. lbs. / 24 N*m
Oil Pan drain bolt - 60 ft. lbs / 80 N*m
Trans pan bolt - 13 ft. lbs. / 150 IN lbs / 17 N*m
Valve body screws 35 IN. lbs / 4 N*m
I'll add some extra stuff
Band Adjustment
Front band -
) loosen locknut.
) tighten band adjusting screw to 72 in. lbs.
) back off screw 2-1/2 turns
) tighten locknut while holding adjusting screw to 30 ft lbs. ( 41 N*m )
rear band -
) loosen locknut.
) back off screw 2 turns on 727 and 518
) tighten locknut while holding adjusting screw to 25 ft lbs. ( 34 N*m )
Den
Band Adjustment
Front band -
) loosen locknut.
rear band -
) loosen locknut.
Den
lniemeyer2
10-24-2012 12:11 PM
bostongsx
09-25-2006 11:25 PM
