oil pan removal
Old 05-21-2009 | 08:36 PM
minipete's Avatar
oil pan removal
ok, ive been pushing this off for quite some time now. but it gotten to be quite bad. and i tried searching for answers and came down to two things. either lift the motor or taking it out. well i dont wanna take it out, so can i lift the motor to replace the gasket? or can i just loosing the bolt up on the pan n slip the new one in? thanxz dan
Old 05-21-2009 | 09:16 PM
BigIron70's Avatar
Cummins Guru
I pull the trans out when replacing pan then loosen motor mount bolts and raise engine up a few inches to get pickup tube out and pull with the pan. Usually takes 8 hours on a lift with trans jack never did it on the ground might be harder to do that way. If I had to pull engine I would change rear main seal and front crank seal also. It's still a lot of work, did you try tightening the bolts first and are you sure it's not the rear seal leaking?
Old 05-21-2009 | 09:29 PM
minipete's Avatar
havent tired tighting the bolts down but well try that first, its leaking rite above the cross membrane and the pan is about the place i can c it leaking from
Old 05-21-2009 | 10:30 PM
Riflemanusmc's Avatar
Registered user
Have you tried taking the bolts out and puttin RTV black on the threads yet? Could be just the bolts seaping oil..
Old 05-22-2009 | 01:05 AM
minipete's Avatar
Nope I haven't but wat is rtv black? And where can I get it. Gotta be worth a shot to give it a try
Old 05-22-2009 | 01:47 AM
roxxx's Avatar
take the valve cover off and drape it with something so no debris falls. In loosen motor mounts and trans and t case, down pipe off turbo (take off) take hood off swear alot drink beer swear some more swear again at dodge engineers phone local dodge Chrysler dealership ask how much to fix oil pan gasket
Bite toque when they tell you 20 bucks for gasket 980 for labor brink more beer heh heh drink brink at this point drink more beer ,drain oil in motor
swear at dodge and Chrysler engineers and then remember you have a 4x4
and giggle because as bad as you think it is, you have to remember you don't have a 2 wheel drive and in the end you have that feeling it would be easier to pull the motor ..... ummm before you do anything though buy beer
Old 05-22-2009 | 10:11 PM
oilcan64's Avatar
what kind of beer...wouldn't it just be cheaper to buy a keg?
back on topic...that cross-member of whatever it is called the u-shaped piece of steel under the oilpan of my truck is cover in what looks to be old oil and my bolts look a little wet- should i do the rtv like riflemanusmc said- seems to be a good idea
thanks...ohh i hear ya- you meant root beer right?
Old 05-22-2009 | 10:20 PM
BC847's Avatar
1st Generation Admin
Go here ~ https://www.dieseltruckresource.com/...=213272&page=3
And start reading with post number 52 (in case you forgot the oil pipe gasket ).
Old 05-23-2009 | 07:12 PM
minipete's Avatar
bc847 thanxz for the tip, and the beer tip too that always needed lol, but anyways just got some new tires on the other day and they put the truck on a host and i was able to peak around well they did the tires and it coming from the drivers side of the motor, kinda around the motor mount area or under the power steering pump, cuz that was really oil there so im still fishing for the leak yet...... and thougtht of what it could be in that area?
Old 05-23-2009 | 08:05 PM
BC847's Avatar
Most likely it's the vacuum pump, perhaps followed by the gasket that seals the injection pump to the block. The vacuum pump typically leaks right there between the vacuum pump and the power steering pump.
There's a kit to rebuild the vacuum pump, but for what it is, it's over priced. Perhaps those that know the individual part numbers will chime in. . . .
Crimedog
09-25-2008 12:28 AM
tex23455
07-25-2007 02:31 AM
bostongsx
09-25-2006 11:25 PM
jlboren
10-13-2004 10:49 PM
tgleason
06-19-2003 08:26 PM
Quick Reply: oil pan removal
