oil on leading edge of fuel tank
my mechanic has sealed up darn near every leak in my machine but every time I take a long trip, I see a bunch of oil drops on the leading edge of the fuel tank.
could it be oil leaking out of the Getrag? it's overfilled 1 1/2 quarts
my does the same thing, it is the out put seal on the t-case going to th rear axle. it wont leak juct sitting there and if you wash it you may miss it all together. if you wash off the back of the t-case and go for a little drive, and then get under it u may see a little oil behind the drive shaft yoke. or if it is like mine you will see drops of oil
hope this helps
Jim
hope this helps
Jim
maybe it's not oil... check to see if it's grease from your u-joint? if it got wet with water (say a rainstorm) it might look a little more like oil. I dunno, just trying to help.
CascadeFirstGen
09-19-2013 08:38 AM
Beta
10-28-2011 10:26 PM
M Penwald
15
03-09-2011 06:23 PM
dervolksfuhrer
01-31-2008 09:10 PM
