Odometer unit that screws into transfer case is stripped. Any ideas?
The odometer and milage reader that screws into the side of the transfer case is stripped, dont know if its the part that screws in or the female part thats messed up. It screws in about 3 threads and comes loose. Its on a 93 5-speed cummins dually. Can anybody tell me how to go about fixen this?
I really cant tell which part is stripped. I know you can screw it on about three threads and it pops off and comes loose every time. Sounds like i might have to replace the whole thing.
yes but if you replace the whole one section that comes off and it isent stripped you spent $100+ on a part that wasent a failure, so just take a flash light under there and look inside the female end and then look at the male end. then you will be able to tell
Burris, there are potentially three parts that you could be reffering to, the Gear Housing Assembly, that sits in the Transfer Case itself, the Gear Reducer, which some models use and some dont. or the Variable Speed Sensor.. the same parts that drive the speedometer also drive the odometer.
all three are easy to replace, this article will describe which each is and has a photo of each.. Hope it helps!
https://www.dieseltruckresource.com/...d.php?t=198123
DECJ
22
08-28-2010 07:02 PM
RuralCruiser007
03-22-2010 01:03 AM
