Odometer issues other then the gears?
Hi I have a 91 first gen an my speedometer an odom/trip work fine then the trip and odom will stop working for a couple miles or so then it will work normal it shouldn't be the gears would it?
My 92 speedo jumped around like that and it was the speed sensor wires rubbing the drive shaft and wore thru the insulation. Taped them and tied them up out of the way and no more problems.
I'm having the EXACT same issue. Speedometer works just fine but the odometer stops working for a couple hundred miles at a time...sometimes 20-30 miles at a time. no real pattern. I checked my gears and they are just fine...no missing teeth or cracks. surely somebody has some insight
jaconst
07-12-2013 03:58 PM
