Odd exhaust question . . . ..
Old 02-11-2005 | 10:48 PM
BC847's Avatar
1st Generation Admin
Question Odd exhaust question . . . ..
Hey folks, so I've got the 4" exhaust system on order, and was cyphering which muffler to get. I've seen reference to the Donaldson brand as being quiet while still free-breathing. Some have even mentioned going with the 4" in/out 8.5" x 34" muffler combined with the matching resonator for the best of both worlds.
Without getting into prices, the resonator is about $3 more than the muffler. Looking at the two, it appears the resonator may just be a short version of the bigger muffler (I'm not sure of the internal construction of the resonator).
Why not save $3 and just run two of the full-size mufflers (in series)? It seems it'd be much quieter.
There's a world of room under there (ClubCab w/8' bed).
For comparison purposes; Muffler (Link) and Resonator (Link)
Anybody care to comment?
Old 02-11-2005 | 10:56 PM
jiMMyCTD's Avatar
stright pipe it, you wont be disapointed, unless you haul horses or something. i can carry a convo and listen to teh stock radio just fine in my single cab
Old 02-12-2005 | 12:06 AM
Forrest Nearing's Avatar
don't get that muffler, it doesn't flow well...
forrest
Old 02-12-2005 | 01:00 PM
BC847's Avatar
forrest
Soooo, . . . . . .. you would suggest?
Lemme dig around in here; http://www.fleetguard.com/fleet/pdfs...mminsturbo.pdf
Old 02-12-2005 | 01:32 PM
I dug through the donaldson catalog one time and compared numbers w/ the mufflers on airflowonline. that one didn't flow well. I think the one for the Detroits was decent. just go to the donaldson online catalog, and look at the flow numbers.
Forrest
Old 02-12-2005 | 02:25 PM
BC847's Avatar
Arrrgg!! Danged fine print!!
I wish the Donaldson cat was more descript! https://dynamic.donaldson.com/webc/W...?section=10210
They use estimates for the noise reduction figures. And to top it off, they present with a wide range (10 to 15 db for example). Those of you familiar with the decibel notation system know that a 3db change amounts to a doubling or halving of acoustic power.
With that, the noise reduction estimates Donaldson gives, cover a couple city blocks.
DOH! And no pictures.
Old 02-13-2005 | 08:29 AM
fearthedeere's Avatar
Id put a magnaflow on it if ur not gonna straight pipe it later.
Old 02-13-2005 | 12:25 PM
BC847's Avatar
Well, for now I reckon it'll be straight-piped till I can figure out what I'm gonna do.
Thanks again folks.
Old 02-13-2005 | 02:01 PM
str8 pipe > *
Old 02-13-2005 | 04:41 PM
BC847's Avatar
forrest
Just so it's been asked, what are you comparing it to?
According to Donaldson, that particular model https://dynamic.donaldson.com/webc/W...tml?item=22723
Flows:
A - Inlet Diameter (Inches): 4
B - Body Diameter (Inches): 8.5
D - Overall Length (Inches): 40
E - Outlet Diameter (Inches): 4
Rated Flow LR (CFM): 1800
Rated Flow MR (CFM): 2546
Rated Flow HR (CFM): 3119
Back Press LR (In Hg): 1
Back Press MR (In Hg): 2
Back Press HR (In Hg): 3
Attenuation (dBA): 8-12
Product Type Description: Muffler, Round, Style 1
Primary Application: OFF ROAD APPLICATIONS
It appears to flow pretty good compared to others they manufacture. NOISE wise, it doesn't do so well.
I did an attribute search of their products and found that, looking at the style-1 (round body, centered in/out), 4" in/out, they averaged just under 1000cfm (LR cfm) to around 1800 or 1900cfm (HR cfm). Those higher flowing models presented with an average of around 10 to 14 db of attenuation. If one wants a quieter rig [15 to 20db attenuation (or more)], those upper numbers are gonna drop an average of 200 to 300cfm (those are best guess averages by the way )
Hmmmmm. . .. . . .
FYI: my search; https://dynamic.donaldson.com/webc/W...tr_max_rows=73
Old 02-13-2005 | 05:36 PM
maybe I was looking at 5" models and compared the flow on that 4" to them? sorry... also, I was looking at 51" models, not 40"ers
just get the 51" model w/ the highest flow... if you're not happy, run a resonator in front of it...
personally, I'd just run it straight!
Old 02-13-2005 | 06:04 PM
BC847's Avatar
The 5" do take a big jump in flow compared to the 4".
Still digging.
Old 02-13-2005 | 08:34 PM
BC847's Avatar
Good informative reading (albeit on a little larger engines )
http://www.ashraeregion7.org/tc26/pa...st_Control.pdf
Asher
07-16-2011 01:40 PM
craneage2001
16
12-10-2006 08:41 AM
dodgeguy71
04-22-2006 03:39 PM
doomgaze
03-01-2006 10:02 PM
jrs_dodge_diesel
02-02-2005 11:09 AM
