O-rings for the valve covers.........question
Ok, I am planning to do a valve adjustment on my 93' next week. I have new Cummins brand valve cover gaskets and the appropriate tools to get the job done. I did some reading on here and discovered that there are 0-rings that seal the valve cover bolts. Here are my questions:
What do these o-rings seal exactly?
How many o-rings are required for the valve covers?
What are the o-rings made of (special materials for oil/heat exposure)?
Does any have a part number or price for a set of them?
Thanks!
Thanks!
I just did the same thing a few days ago. I got my gaskets at NAPA and the o-rings came with the valve cover gaskets. As far as I can tell they're just run of the mill o-rings to keep the oil from spewing out the top of the valve cover. You only need one o-ring per valve cover bolt. You'll see how they sit when you pull the valve cover bolts...that is if the o-ring hasn't rotted away. Mine were. Are you sure they didn't come with your valve cover gaskets?
Nah,
the valve cover gaskets I recieved are true CUMMINS brand ones and did not come with the o-rings. I'm guessing this is an item I can get locally at the dealer or diesel shop? I just want to make sure I get the right ones.
1st Generation Admin
Crap! Geno's Garage sent me six rubber noise isolators (the rubber thing that holds the beauty plate above the valve covers) instead of the O-ring.
rubber hose smashed between the bolt head and the valve cover works pretty good, cut it thin and tighten down the bolts,no oil for about 500 miles cheap and quick.
I know, I know....I should have used the genuine article . It was kinda a last minute thing to run the valves and change the valve cover gaskets. Minus 20 horsepower for me!
ahire
13
10-17-2008 12:50 PM
12VRoush
10-15-2007 08:00 PM
1320
03-08-2005 08:56 PM
