Nv4500 V10
Nv4500 V10
is there any diference between the v10 and the diesel nv4500 ie input shaft, bell houseing, output shaft, t case, I found one and would like to use it if I could
thanks jesse
thanks jesse
4500 swap
call drivetrain.com in las vegas nevada, they have the adapter kits for 4500 to install in 1st gens, its an adapter kit with a bell housing, that allows you to keep the early clutch and hydraulics, bellhousing comes from advance adapters in paso robles ca. if you need to change the input shaft, i know a transmission place you can get the parts, pm me if you want resources, good luck, joe.
thx for the straight answer Bill
