nv4500 swap issues
nv4500 swap issues
I'm in the process of swapping an nv4500 into my 93 club cab 2 wheel drive and i hit a snag. I have a 2nd Gen adapter plate, a 2nd Gen starter and the clutch is a rebuilt south bend dual disc 3600. For some reason my starter is not engaging. It's like its bottoming out. I put a bore scope inside the slave cylinder to see what i could see but it's not the best view. just curious if anyone else has had this issue and how they resolved it. Thank yall in advance
I have never used a dual disk clutch..…but don't they come with a starter spacer?
Did you trim the inside frame rail edge near the starter? You need to remove about 3/8" of material to clear the starter. If you didn't then maybe the starter is binding up, since it is not seating properly?
