np205 gear question
np205 gear question
Can I take a gear out of a auto (23 spline) np205 and install it in a manual (29 spline) np205? If so is there a seal or o-ring that should be replaced? Can it be done in the truck or do I need to drop the t-case to install? Thanks, RAM
You mean the piece that sensor screws to? If so yes it had one on it, I unscrewed it from the transfer case prior to removing the old one. Then simply screwed it on and plugged the wire plug onto it.
What I am trying to find out is if I can pull the gear out of both then put the one in the auto into the manual? The truck has 3.54 gears. I assume the manual transfer case is setup for 4.10's being I was off by about 10mph.
Look at the number on both of them. I bet it is the same drive pinion.
I had a Tcase from a 3:54 truck apart. I took the Tcase from my 3:08 geared truck apart. Both drive pinions had the same number laser etched into them.
^ I have never had one out. Is it just held in with the one big nut? Then just pull it? I believe there is a white nylon gear. Correct? Thats what is different, right? Is there an o-ring? WHat keeps the grease in? Thanks, Robert
The drive pinion gears are steel. It is a one piece setup. Just unscrew it out of the Tcase. The numbers are etched on the side of the steel body.
The drive gear is plastic. Its a 7 tooth gear. On the color your guess is a good as mine. With over a decade of oil soaking. There is not telling what the orginal color was.
Both cases I took apart there was no o-ring or seal on them. The reseal kit I bought didn't have o-rings in it eather.
93D250
Cummins Conversions
40
02-18-2019 04:26 PM
u.s mma
12-19-2008 09:02 PM
24seven
15
01-05-2008 01:22 PM
