NP 205 transfer case
I can't find this anywhere. What lube do you use in the NP 205 and how much?
I am here in Pa. Normal temps run from 0 to 100*. I would say normal use stuff.
thanks
thanks
I have the shop manual but I can't find a thing about the capacity of the case. It says above 32*F to use SAE 50 motor oil or SAE 90 gear oil above -10*f. I was just wondering if you guys have a reason to use something else. The big thing right not is how much does it hold?
thanks
thanks
I just wanted to have the right amount before I dumped it. Well anyway I went ahead and drained it. It looks like about 2.5 quarts so I guess I'll get three and see if I can get it to come out the hole. I'll let ya know.
From what i remember they called for anything from the thickest to the thinnest stuff out there base on temps and how severe the use was. I used the stuff for severe extreme duty. Unless your in the artic I see no real need to put thinner oil in there for the cold.
I have three NP-205s that fare very well with 85W-140 gear oil.
jeepinaround
06-15-2005 10:01 AM
gwhammy
03-29-2005 05:12 PM
