not really impressed with 3200 rpm spring
Old 06-12-2007, 09:01 PM
sdstriper's Avatar
Are you getting full throttle travel? High idle stop adjustment has been mentioned, I removed mine...
Also, I would make sure the throttle linkage is "dialed in" and the TV cable is adjusted right.
Old 06-16-2007, 08:47 AM
gomerpile's Avatar
well one more thing u might want to check is your oil level, keep a constant eye on it. i know many at this point are wondering why, you might have a dying fuel pump. mine bit the dust a little before i swapped from 21cm to the 16cm, and i thought it was worse. so a little after i checked the oil, it was coming up, and i changed the fuel pump, and now i have so much more power when i want it. it is worth a check. now i know the power of the 16cm
Old 06-16-2007, 12:57 PM
dpuckett's Avatar
Originally Posted by gomerpile
.... now i know the power of the 16cm
No, you know the power of a good pump. It is amazing what a seal kit and recalibration on a stand can do for these things.
DP
Old 06-16-2007, 10:41 PM
97catintenn's Avatar
I'm thinking the same thing sdstripper is thinking. You have raised the gov. spring, but didn't adjust the throttle linkage to allow to motor to hit full throttle. I removed my throttle stop screw completely and put it in the toolbox. Other members here at DTR told me that that's where it belongs.
Keep in mind, that my truck is a 91 and was seriously tuned down from the factory.
JasonblkZ06
06-21-2009 12:39 PM
robert78.5
19
11-09-2008 01:44 PM
Tuckerdee
05-02-2005 04:58 PM
sammy340
10-14-2004 12:28 AM
driverswanted
03-13-2004 04:48 PM
Quick Reply: not really impressed with 3200 rpm spring
