Non IC/ 9mm Heads
Old 01-02-2006, 11:46 PM
bigragu's Avatar
Originally Posted by jleonard
Yes by all mean do your work to the 7mm head.
Cummins made a product improvement by changing from the 9mm to 7mm. Take advantage of that. They did it for a reason. To handle more heat.
Plus all of the performance injectors are 7 mm.....then you can take advantage of that plus have all the washer thickness options.
Jay
School me on the washer thickness deal, will ya? I installed a set of 40 HP injectors from BD diesel performance and I just followed their instructions and installed the new washers that resembled the stock thicknesses. The kit did come with 2 other sizes...did I mess up? Sorry to hi-jack this wonderful tread. Carmyne
Old 01-03-2006, 02:16 AM
bgilbert's Avatar
Originally Posted by rockjeep73
Can you use the 9mm injector adaptors with any injector for the 7mm head? Or is that just for POD's?
You can use the 9mm to 7mm injector adaptors for any 7mm injector. Not just the POD's. That is early head (that has the big 9mm bores), later injector (7mm tip) be it POD, 91.5-93 stock injector, EDM with 7mm tip, 370's etc with use of said adaptor.
Can't go the other way. Later head (smaller 7mm bores) big 9mm injector= NO.
Bigrag, varying injector washer thickness can reduce smoke from the POD's at idle, get the tip closer to the piston bowl. I'm sure more, someone else will have to chime in, its late.
Old 01-03-2006, 04:29 PM
Carmyne, AFAIK the POD's are the only injectors that need thinner washers to run cleaner. As long as you're not putting out a constant haze at idle you can't be too far off.
PeytonMaterne
05-13-2007 08:29 AM
boostjunkie1
11-05-2006 11:40 AM
tboling
01-17-2006 04:46 PM
drew03
10-13-2005 07:34 PM
Quick Reply: Non IC/ 9mm Heads
