No sound on Flasher/turn signals?
Hi all, when i use the flasher/turn signal, it lights up, but there's no sound. Does this mean i need a new flasher or did somebody just unplug it?
Also, i'm wondering if i need a heavy duty unit for towing? I'll be towing a 16 foot trailer with front/side/rear lights.
Thanks
Brent
Thanks
Brent
If the signal on that dash isn't flashing then its most likely the flasher. BUT I have the same problem with my pickup when I've been driving it for about longer then an hour (only does it when its warm) but when I first start it up its always fine. I've tried 3 different flashers and still have the problem.
Good Luck
Good Luck
Flasher.
When the flasher stopped working om truck some years back I tried a couple of Auto part houses brand and could never get them to work. I hate say it but the only one that worked was a new one from the dealer.
Jim
Jim
Are you sure the Cummins isn't masking it?
And it seems to have a good MTBF like the Cummins.
Jim
http://www.truck-lite.com/webapp/wcs...9188&langId=-1
Originally Posted by serious
Flasher works, but just doesn't make a clicking sound.
If it flashes fast when you connect to the trailer or don't flash at all, then change it to a heavy duty flasher.
Flashers are LOAD SENSITIVE. The higher the load in the circuit, the more heat on the bi-metalic strip and the faster it works.
If you got a quiet one......bonus! It just means you can listen more to the sweet sound of a CUMMINS...............
GreatTruck2001
06-15-2012 01:20 AM
Tonasket Bill
08-18-2011 10:39 PM
redruM Hauler
10-06-2007 09:18 AM
Sky-dogg
04-05-2004 02:26 PM
