No power on my 93 d250
Hello, I drove my truck up to the gate and turned it off and when I went to go crank it there is no acc and it want do anything no gauge movement no voltage at the gauge no wait to start light nothing that usually happens when you turn on key the battery is hot interior light is working if you jump the starter it will turn over but will not crank any help would be great thank you Doug
Is your FSS wire connected.
So does it run? Turning over and cranking are the same thing.
Check for loose/dirty battery cables and grounding points first.
Did the ignition switch feel warm or hot? If so it's possible the the ignition switch went out.
Also second the FSS.
You have 2 feeds to the ignition switch, each though a different fusible link. One feeds the run and start circuits, (start, fuel, 'puter, etc) and the other feeds the run only circuits. (heater, windows, etc.) The common points are the duck foot fuse links and the heavy wire from there to the positive battery terminal. The other possibility is the ignition switch chit the bit. A lot of power goes through that little thing. It might have smoked.
No cranking, ok. Are the headlights bright when you turn them on now? A battery can be hot, but still not have the oomph to crank the engine.
If your test of the ignition switch shows the switch to be good, try jumping the starter solenoid and see if the engine cranks.
Ok guys I finally got my new ignition thinking it was going to fix my truck
Put it on didn't fix it the black with pink strip I believe is not hot none of the wires are hot going to ignition last week it seems that it would be hot one minute not the next where all does that wire go also the center row of fuses are not hot are they key on hot only fuses please help greatly needed thank you Doug
banzaitoyota
09-29-2003 02:34 PM
