No Oil Pressure
No Oil Pressure
I started my truck this evening and had no oil pressure on the gauge. When I reved it the pressure would go up to the normal range. I thought maybe I blew the pump seal and was filling the crank case full of diesel, but the oil lever is fine (although the oil does look a little thin). Since it wasn't rattling I drove it home. The gauge kept falling until it was back to almost zero. Still, it sounds fine.
Probably the sending unit right?
Thanks guys. I do have a spare mechanical gauge that I was thinking about hooking up to test with. I'll let you know that I find.
-mark
-mark
My oil pressure has an optional audible signal available on only high mileage engines: starts out rattling loudly, then over about 30 seconds as the pressure needle climbs to normal and all the wear spaces fill with oil the rattling reduces to a barely acceptable level. I turn up the radio and move off , ...
Well, I tee'd off my bypass filter port and I am pulling down 50psi hot on the freeway and 30PSI at idle. The factory gauge subits othwise....
GlennRMK
05-24-2007 10:46 PM
Power Ram 250 C
02-20-2007 11:08 AM
streetsmoker
02-22-2006 06:47 PM
bigragu
01-24-2006 11:16 AM
CIN'S DODGE
16
12-05-2005 04:14 PM
