no headlights - need help ASAP
You will have to take the instrument bezel and remove the light switch ****.
There is a small spring loaded button on the side. push it in and pull the **** and shaft out. It can be a pain but will come out. once the bezel is off you will see the little plastic panel over the front of the switch. once that is off there is a nut with a slot in it that holds the switch.
Sorry about the other thread going off the rails. there is a guy that can be a PITA.
horselady
01-27-2009 12:01 AM
stock03
09-30-2008 09:03 PM
usedtostrokeit
07-29-2004 10:10 AM
