NITROUS QUESTION, Before or after turbo?!
Im installing a 100hp shot of nitrous, should i do it before or after the turbo, what will happen if nitrous has to run through the turbo?!. it would make it easier for me...
if your using it for power, best if closest to the engine, in the intake. If your using it to control egts, it s best if injected in the hottest charge air, that being between the turbo and intercooler. That would remove the most heat since its the greatest temp difference.
Don't inject the nitrous before the turbo. One thing you have to keep in mind, the turbine can spin up to 150,000 RPMs (over 2300 times a second) at full boogie. When little droplet of anything (nitrous in this case, this can also happen with water/meth injection) impacts the turbine blades, it will start to erode the surface of the blades. If after enough use, your turbo may be trown off balance and impact the housing and the turbo will no longer be useful.
Mike D
87
04-10-2008 04:18 PM
desertchecker
14
02-18-2008 10:32 AM
sallyman1
33
01-11-2008 10:41 PM
dodgemaniac
06-05-2007 11:21 PM
04.5HO600
06-29-2005 09:59 AM
