next buy?
next buy?
I am thinking of buying a htt 3 or 4 upgrade or some 190 injectors what would be the best buy for my truck in my truck i have a 3200 spring,shift kit,14 cm w/g housing or is there somthing better around 400.00 or less thanks keith
1st Generation Admin
How does the truck currently present? EGT's, can you turn in the fuel screw more, etc. . . . .
If you're running hot now perhaps the turbo upgrades are in order.
I would say it depends on what you plan to do with your cummins. if you want to play then I would say get some bigger injectors. if you want to haul I would go with the turbo upgrades. Air is always a good thing to have first before fuel but its taking me a long time to figure that one out
Not to go off the subject but i noticed you have bags and just curious as to how you like them and if it helps the ride
Jake
Jake
i dont ride with air but could not do with out them anything i put in back with 40 psi in bag the back of truck is still higher than the front when i have my camper in back with air in front it rides great the camper is 1400 lbs dry
ZombieSoldier
15
11-08-2010 10:05 AM
DIESELWRKS
13
11-02-2010 08:15 PM
wanago
12-27-2007 06:11 PM
93' Shorty
12-28-2004 02:46 PM
