New or reman PCM sources?
Is anyone still fixing the PCM's for 1st gens, or do I need to try to find one from the dealer? (related to my grid heater troubles) I would rather have the system working as designed than have to manually preheat and post heat cycle with a push button.
Im pretty sure i saw some on ebay. if im not mistaken, they had a life time warranty too.
in fact there is one
http://cgi.ebay.com/ebaymotors/DODGE...Q5fAccessories
good call, I figured they would be more rare than that, but these guys at least call for the same computer up to 95
When I was looking for one for mine, also a 91.5, I could not find one anyplace. The 91.5 is different than all the other ones, they don't control as much stuff. I believe there are 2 different ones, one for auto trans and one for manual. All the auto places had them listed but they could not get them. Cardone will rebuild your unit but I don't know the cost or down time. I had grid problems too and put them on a timer. Good luck
I found one at a place called "Fourth Generation Engineering", it was a few years ago but I don't remember it being too expensive. It was designed for glowplugs and came with a single 80 amp solinoid which I did not think was up to running the grid heaters so I used that solinoid to trigger the 2 existing solinoids on the truck. I also tied it into the wait to strart light so when other people use my truck it operates like factory. It also has a temperature sensor that keeps the grids on longer when it gets colder but it will also heat for a few seconds even when it's 80 or 90 degrees out so I disconnect it in the summer.
EdmontonCanada
10-18-2014 09:40 AM
chumstone
03-17-2007 11:05 PM
oldsmokey97
12-07-2006 06:41 PM
