new headlight switch Now no parking lights
I was driving home and the headlights turned off then on again then off and on . Sounded
like a circuit breaker tripin somewhere under dash or hood . So I changed the head light
switch and now I have no parking lights . when I turn the H Lights on they work but no
other light do . I can pull the switch about half way from off and parking and the lights
come on but if I pull to first or second click they go off . Thank you for your BRIGHT ideas
Can you bypass the light switch and put two toggle switches in . One for the headlights
and one for parking lights . If so what wires go together . When I get time I will just buy a
new harness and do it right a few years from now ha. Thanks
My guess is that you popped the parking light fuse while changing switches. Check that fuse.
A dime in the cigarette lighter pops the parking light fuse very nicely, too.
Thank You Dave For The Help ...you Are The Man You Fixed My Problem . I Checked That Fuse And It Looked Good . I Then Put A New Fuse In And It Worked . I Now Can See The Light ...thanks Dave And Dtr
If need be, look at a new switch and you'll see it, makes it easier to find .
Banzai Bob
02-24-2010 12:24 AM
jlipskoc
10-24-2005 01:16 PM
CHarlan
08-06-2003 08:40 PM
