Need a wastegate cover plate/outlet
Hi, I'm planning on replacing the 12cm non-wastgated hot side with a waste-gated 12cm housing, but need the coverplate/output flange. Classifieds belong in the classified section
I'm assuming you mean the wastegate actuater/diaphragm for opening and closing the wastegate? If that's all you're after just take a small piece of stock, aka flat metal, and make a bracket to hold things open. I got my housing off a 2nd gen and it never came with the actuator either. Without that plate on there, that left spare bolt holes that I didn't need. I measured out a piece of stock, drilled one hole in each end of it, put one end over the pin like lever coming off the wastegate, then stuck a bolt through the other hole in the stock and into one of the open bolt holes. Grantit I had to do some measuring and figuring as to when my wastegate was closed but it all worked out. Best part was, all it took was about 2 inches of aluminum and a bolt. Cheap and no one can even see it.
Keep in mind it'll always be building boost and therefore only limits when everything tops out so keep an eye on it if you've got many mods done.
The more boost you build the cleaner your truck will burn which means there will be more air per percentage of fuel, thus emissions testers shouldn't fret too aweful much.
Remember... boost is your friend
How about a source for an aftermarket flange - something I can fab up a new 4" downpipe too? Also, if anyone has an idea of where I can get a gasket from (and/or P/N), I can use it as a pattern to make my own flange.
sallyman1
02-10-2008 06:17 PM
ataboy9026
02-22-2006 05:09 AM
MoparRiggan
10-13-2005 11:54 AM
