Need a turbo shaft
Need a turbo shaft
Where can I find a new shaft for my H1C? Pulled it apart to rebuild, and install a 12cm housing and GDS 60mm, and on inspection of the main shaft(?) found a few marked that looked like where it had a groove washed into the shaft in 2 or 3 spots around the shaft. I know they were not made into it, so would like to change it out. Can anyone point me in the right direction? Will even take a good used shaft if I can find one, but am having no luck, as I'm not sure what the proper name is.
Thanks.
Thanks.
I have the h1c from my '90. Compressor wheel inducer is only 50mm but the wheel and housing can be replaced. If you're just looking to use the shaft, I'm sure this one's in good shape. Never shutdown hot and always cooled to at least 400degs. I was thinking of rebuilding it to keep it on hand as a spare for whatever reason but I don't think I'll ever get that serious about. PM me if you may be interested.
I would get ahold of http://www.gdsdieselparts.com/ they have good service and prices on Holset parts.
Det 1
17
12-22-2009 08:32 AM
captntim
12-26-2008 02:53 PM
4x4dually
01-05-2007 01:07 PM
signature600
10-05-2005 01:43 PM
