need some help getting started
Old 07-05-2009, 08:25 PM
BearKiller's Avatar
Originally Posted by minipete
And bear I under stand wat ur saying checked that lock screw and its pretty snug
Let's go back to the beginning.
Prior to removing the pump, before you loosened any bolts/nuts/screws, did you loosen the pump shaft-lock screw, remove it's C-notched spacer, and then SNUG the screw back down, thus locking the shaft position in the pump ??
Then, when you got everything put back together, did you loosen the shaft-lock screw, re-insert the C-notched spacer, and snug it back ??
Old 07-05-2009, 09:31 PM
minipete's Avatar
No, umm.... We took the pump out then took the C spacer out snug did the work, put it on bfor installing the pump back into the truck
Old 07-05-2009, 10:57 PM
BearKiller's Avatar
Congratulations; you have lost pump timing.
Did you scribe the key-way location on the pump-housing before moving anything ??
If so, then you are only half-a-lobe off; if not, then good luck.
Old 07-05-2009, 11:02 PM
minipete's Avatar
Can u xplain the scribe key-way?
Old 07-05-2009, 11:11 PM
alwaysonDTR
Alwaysworking's Avatar
did you have the engine at TDC before you pulled the pump?
if so retiming the pump is easy you line up the keyway with the tick/scrib line on the face of the pump which is in about the 5o'clock area
Old 07-05-2009, 11:14 PM
minipete's Avatar
No we didn't, it was about the 230ish 3 o clock spot I do member that
Old 07-06-2009, 11:25 AM
minipete's Avatar
Ok got a question for yall, got a parts truck, if we lock the pump @ tdc and take it out, and lock my timing gear @ tdc well it work?
Old 07-06-2009, 12:57 PM
apwatson50's Avatar
As long as you didn't move the IP gear in relation to the cam gear, and you install the pump and the key on the pump goes in the key-way on the gear, then the timing will be close enough to start. As long as the key is in there it will be close enough.
Traveler04
07-26-2010 10:10 PM
3500lstar54
10-20-2006 05:36 PM
csramsey640
11-16-2005 08:16 PM
RAMTECH
02-05-2003 11:10 AM
CRobey4393
10-28-2002 10:29 AM
Quick Reply: need some help getting started
