need some help getting started
Well today got my pump back in, and bleed the lines outso fuel was coming out of lines a good bit, closed em up and still no fire! Wat did I forget to do?
Got all wires hooked up is it possible to get the shut off selonid backwards? Also tired using a tad but of starting fluid but not much sounded like she wanted to go but didn't! It sounds like no fuel but I've loosing line up to check and make sure and it still pushing fuel out!!
Yah we've tired hold the throttle open some just not the whole time, crossy are u saying prime it while the lines are open? Cuz I tired pushin the prime buttom for couple mins already thanxz dan
Well went to work on truck this morning after got off work, and still nata I've primed, I cracked em open multpi times had 3 lines open, all closed, 2 open, all closed, all open, all closed and still don't wanna do the "I wanna start" sound any idea wats going on with this? Thanxz dan
Well went to work on truck this morning after got off work, and still nata I've primed, I cracked em open multpi times had 3 lines open, all closed, 2 open, all closed, all open, all closed and still don't wanna do the "I wanna start" sound. I even have a puddle of fuel on the ground that's how many times I've crack the lines open and nuthin, any idea wats going on with this? Thanxz dan
That is also my guess.
It is a very easy mistake to make.
The engine stops with the pump-cam under spring-tension on a lobe, wanting to roll on down into the valley.
What happens is the lock-screw is not snugged enough to resist this tendency and the pump-shaft thus moves out coordination to the gear key-way.
Am I making sense ??
Ok just got around to looking @ truck again after long weekend, and wanna, I looked in there using a mirror and a bright lite, the key still in slot on the timing gear, also tired with starting fuild she sounded like it wanted to go but sounded like lack of fuel/low idle, but I was holding the foot pedalall the way to the floor!
And bear I under stand wat ur saying checked that lock screw and its pretty snug
Any other suggestion? The pump ran fine bfor taking out to replace the fulcrum!
