NEED QUICK ANSWER. 05' intake horn on my 89'?
I found a guy with an intake horn off his 05' cummins and need to know if it will fit my 89' It looks like it should be a bolt on, but I'm over seas right now and cant compare in person.
Thanks for the help guys.
I bet the bolt pattern would be the same, but remember you have a master cylinder in the way where the horn jogs to the driver side. Might have fitting issues. Working on an intercooler install?
the second gen ones that come forward should work, but the 24 valve ones come directly off the side and dont have enough clearance with the master..
I used a second gen intake horn on my 90.
It worked fine.
I'm sure there would be clearance problems with the third gen horn.
Btw, the second gen cooler ended up fitting really nicely too.
It worked fine.
Buckshotmckee
07-07-2005 05:06 PM
Mopar_Mudder
19
05-16-2003 07:34 PM
