need mo powah!
Old 02-02-2003 | 01:45 PM
feets's Avatar
need mo powah!
I've got a 92 D250 that needs to dish out a little more power. <br>I've diddled with the diaphragm, start wheel, and bumped the pressure one turn. The muffler mysteriously transformed into a straight pipe. It's got a 16 cm housing and 27 psi. <br>These little things gave me a whoppin 187 hp and 547 tq. Pretty friggin lame in my book. <br>I've also noticed that it really lays down at higher rpm. Boost will drop to 10 psi before it shifts to OD. <br>What's the best route to get more power out of this thing without running the pressure to the moon?<br>I don't want to change the turbine housing. There's very little lag and I'm quite happy with it.
Old 02-02-2003 | 02:51 PM
Monty's Avatar
Re:need mo powah!
Lame? Remember that the stock hp was measured at the Flywheel, NOT the rear wheels, if you are putting down the amount you mentioned in RWHP then I would say that is a good improvement. With the mods you have mentioned in your post. I dynoed last year and put out 222hp 517tq to the rears. With the same mods that you have. I did however bump the timing up to 1.45*. The best route to go for more power is to get a set of the Delphi/Lucas POD injectors from Piers. adds 60rwhp and 100rwtq. I installed a set on mine about 2 weeks ago. Major inmprovement accross the board. You might want to consider putting an upgraded VB and TC in before this upgrade though.
Old 02-02-2003 | 05:31 PM
Holsteinman's Avatar
Re:need mo powah!
I think those numbers are very good for a first gen. Like OkieBroncRider said you can some pod injectors. My brother has them in his 92 they make good power. One thing your exaust temps will go up.<br><br>Paul
Old 02-02-2003 | 06:23 PM
nascar mark's Avatar
Re:need mo powah!
Like Monty said, a set of POD's will help wake up your truck. Phone me at PDR and I will get you a price on a set. Also try turning out your high idle screw for a little more top end, along with bumping your timing up.
Old 02-03-2003 | 09:02 AM
furious70's Avatar
Re:need mo powah!
how do the POD's effect mpg?
Old 02-03-2003 | 09:38 AM
Monty's Avatar
Re:need mo powah!
Well, if you keep your right foot out of the go peddle you will avg. about the same. If you have a heavy foot like I do, expect to see a 1-2 mpg drop.
Old 02-04-2003 | 02:21 AM
Bushy's Avatar
Patron Saint of 1st gens
Re:need mo powah!
I agree with Monty... if you go easy on the peddle, you'll likely see very little change in MPG. I have found that if I constantly crank it hard into the 3/4 throttle and up range then I see some loss of MPG. Even that can be moderated by tweaking the pump and you loose very little if any at all in terms of power. <br><br>Also I'll toss my hat in with nascar mark... give him or Piers a call. They will set you up with a balanced/tuned set including all the correct washers etc. for the entire install. You won't need to go hunting for all the extra bits and parts like has happened on E-bay for example (as I understand it happened). <br>Also there is a correct washer thickness for these injectors and it is not the normal 60 thou. ones Bosch uses in most of theirs.<br><br>Bob.
rjm022
08-20-2006 07:17 PM
JARHEAD
02-25-2006 11:52 PM
v8440
14
09-07-2005 08:39 PM
PapaPerk
11-29-2004 09:13 PM
Quick Reply: need mo powah!
