Need help quick!
Need help quick!
I've got fueling problems of some sort i believe. Filled up with fuel this morning and on my way to work i have no power at full throttle. Started to pass someone and truck started spitting and sputtering and white smoking a little bit. Its due for an oil and fuel filter change. Gonna try fuel filter first and see what that does. Water in Fuel light is not on! Gonna try some fuel conditioner anyway. Truck has 195,xxx miles. ??????
I have seen a lots of water in fuel sensors not even plugged in on these old 1st gens...
People must forget after changing the filter to plug it back in.
If it happened just after a fill up, I would see if you can drain out any water from the filter.
I would do this before trying to just add fuel conditioner.
If you just filled up with lots of water [could be several gallons], you don't just want to try to emulsify the water into the fuel and run it through your motor.
HorseHauler
13
03-12-2006 11:48 AM
rackshakermac
09-08-2003 07:28 PM
