Need help, Getrag/205
Old 01-26-2008 | 08:15 AM
Proram's Avatar
Thur a week ago i was driving the 92 had it in 4WD (snowy/slick but not bad)
pulled out at a lite, shifted from 1st to 2nd, made a large crack and no go. all gears dead, shifted thru all the TF case gears still no go no real grinding. thought busted a shaft some where. went got rollback, dropped in shop .
finnaly got to work on it last nite. pulled shafts and checked case seemed ok pulled side cover on trans, no parts and seemed tight. pulled tf case and found splines in coupler and input of case stripped, Trans side seems very good yet also found a good amount of water in adapter(splines and coupler rusty) can i just get a coupler and input shaft/ gear ? and if so any ideas where i can get um? don't wanna replace TF case but will if ness.
TIA for any help.
Scott
Old 01-26-2008 | 12:56 PM
feveree40's Avatar
drivetrain.com has the coupler too, and parts for the np205. Give them a call and they should be able to hook you up.
77machomopar
02-13-2009 04:05 PM
dieselcarpenter
08-31-2008 09:11 AM
bgilbert
01-05-2008 01:03 AM
G1625S
09-13-2006 05:21 PM
jive55
02-12-2005 11:40 PM
