Need help in a bad way!!
white smoke
The smoke white white/grey when we were messing with it getting it to run and idle, but at high rpms it bogged down and thick white smoke came out. What does white smoke mean?
Sounds like timing or fuel restriction if its white smoke
On my old toyota I had the line going into the fuelfilter clogged up, changed the filter and still wouldn´t run right, that could be it.
I would take the fuelline apart, or just replace the whole thing, that way you´re sure that´s not it, and it´s easy to do.
Slev
Slev
I agree the price is a bit much for just guessing and replacing parts without reason. Find out exactly what they installed for injectors.
How about running fuel out of a small jug with a short hose straight to the lift pump to see if it runs better , that way it bypasses all the other hoses, valves and filters. If it runs then work back to the tank, if not then go towards the fuel pump.
turned out to be $4,400.00 for an injection pump, injectors, starter, front brakes. pretty shiesty shop, dirty and disorganized. won't go back. maybe I got shafted, but my truck is running again and I am back in business. Thanks for the help!!
So your spent 3700 and then again spent 4400 more Hell for what is has cost you I sure hope you have a Brand New Truck . Sorry somebody saw you coming and sucker'd you into droppin all that cash to fix your truck .
wap
37
03-22-2008 08:57 PM
wap
36
04-16-2007 04:34 PM
