Need a Getreg trans mount!!!!!!!!!!!!
the washers rotted away right? I found the rubber pieces with steel bushings cheap at the local parts place. I had to come up with washers bolts etc. I was going to copy the large washers out of simlar thickness steel but lost interest and used the largest thickest washer I could find. Make sure you have a lock washer or lock nuts as mine fell off.
The washers I used were 1/8" thick for 3/4" bolts. I used 12 I think, 6 per side.
