Need to get this thing to stop smoking on the highway.
So seems I've go a few people telling me my dodge rolls on the coal pretty good when I put my foot into her is there any way I can make it just burn that fuel instead of puking it out the exhaust? 16cm turbo housing maybe or adjusting the star wheel?
Location: A 5th dimension, beyond that which is known to man.
1 Post
these trucks are pretty easy to give a timing bump. they wont slip or get a mis-reading like a p-pump if that makes you feel better
i like the idea of a smaller exhaust housing, or just getting a hx35 for it with the 12cm exhausting on it already.
I'm non intercooled with steep mountains here and I tow from time to time. so hx35 might be outta the question I contemplated it for a while n looking at dads 96 I might do it yet.
1st Generation Admin
- Back the smoke-screw all the way out. You may (also) find benefit by grinding a little meat on the underside of the AFC lid allowing the fuel pin to come up a little higher. This will help with the puff of smoke when you first tip into the throttle.
- Raise the star-wheel up (increasing the spring pressure on the bottom of the fuel pin's diaphragm). This will force the engine to come up with more boost before the fuel comes on hard (not as aggressive). This will clean up the part throttle smoke. You'll have to dink with this a few times to get the throttle response where you want it, while keeping the smoke under control (like you want it).
- If you're planning on running an aftermarket fuel pin, get one like the M&H M3. It has a more conservative ramp for bringing on the fuel (again, not as aggressive).
Actually, more timing may not help in terms of improving part throttle smoke, as increasing the timing will put more heat of combustion in the cylinder (putting more heat energy to the crankshaft), and less heat of combustion out the exhaust to power the turbo (reference the apparent loss of boost when turning up the timing).
The Hx 35 is a better turbo than the stock one! You now probably have a 18 or 21 exhaust housing. Go to a Hx35 witha 12 wastegated unless you have a lot of extra fuel. It will spool up much quicker!!! If you have a lot of extra fuel try a 16 housing.
You NEED to push the pump over towards the head 1/8 inch and you really need to get a 3000 rpm spring in it.
You will be happy and the truck will be much different.
Do you have pyro and boost gauges??? Very important for EVERY modified diesel.
just listen to brandon on this one...its very detailed for bumping your timing click
joefehr
07-21-2011 08:46 PM
96FLaTBlAcKRaM
11-04-2010 10:46 AM
draskobnsf
06-02-2007 12:15 PM
royta
11-06-2006 08:19 AM
