need assistance right now from all that have done the KDP
Old 03-30-2008, 03:01 PM
GLHS's Avatar
I have done a few so far and I use the Napa fan clutch removal tool for the nut and a large (6-8" jaw) adjustable plier to hold the fan pulley.
I use an impact when I can and zip the 6 bolts right out of the fan pulley and pulley mount.
Old 03-30-2008, 03:06 PM
CaptainChrysler's Avatar
Here's a method thst works good:
Find a cheap wrench that fits the clutch. Cut a piece about 5" off the open end. Use the air hammer to drive the stubby wrench. Will get even the most stubborn one loose.
Lisle tools sells a kit like it:
http://www.autobarn.net/xxxw-lis4330....shopzilla.com
I know it's an expensive set, but you can use the idea on a 5$ HF wrench.
Old 03-30-2008, 04:13 PM
daking's Avatar
also if your going to remove the fan, witch is alot easyer then you guys are making it sound, get a vise grip (the original type) that has the chain on it, put it on the pully get a wrench and put it on the nut and beat on the wrench with a hammer, it will come off very easly
also put carboard between the rad and fan so that when the fan falls it doesnt puncure the rad
joel
Old 03-30-2008, 05:41 PM
bigragu's Avatar
now comes the crank pulley
Fan, clutch are out. Any tips on the 4 cranshaft pulley bolts? Dave(Wanna) cleared things up on the bolt thread direction, now how do you keep the pulley from turning when trying to turn the ratchet counterclockwise(lefty loosey)? Again, I still have the drive belt on. I do have the barring tool, but that would mean 2 people, and I am solo. Let me know
Old 03-30-2008, 05:43 PM
Just stick the barring tool in the hole with a breaker bar on it. There's so much mechanical advantage that alone is usually enough to hold the crank - but it'll definitely stop when the breaker bar hits the frame.
Old 03-30-2008, 06:15 PM
dieselJon's Avatar
I put the wrench a little past 90* (about 100-110*) to the right of the bolt and gave it a sharp rap with a hammer upwards. So if the bolt is at 0* (top of the pulley) the wrench would be about the 5 o'clock position. Savy?
That is how I got mine off with out a barring tool AND the engine was out of the truck.
Jon
Old 03-30-2008, 06:54 PM
GLHS's Avatar
I forgot to mention that after I remove the fan but before the pulley, I break loose the damper bolts. The extra tension of the belt helps of course.
A 2nd gen fan is harder to get out.
I can literally from start to finish have the fan clutch out in about 1 1/2 minutes.
When you put the fan clutch on with belt installed, you only need to tighten until belt slips on the pulley. It cannot loosen up; it will only get tighter over time.
Old 03-30-2008, 07:07 PM
1st Generation Admin
BC847's Avatar
I put some anti-sieze compound on the threads of mine to help.
Old 03-30-2008, 07:46 PM
Dean Snow's Avatar
Geeze. Sounds like yours was a pain in the butt to get off. When i did mine it took about an hour from start to finish. Everything came off so easy. Guess I was just lucky.
Old 03-30-2008, 08:09 PM
daking's Avatar
if you havent done the balencer yet just get a chizle and tap all around it, from top and bottom, they come of easy and i have never damage the case or cover doing it that way, the 4 bolts will be a little tough but nothing a good breaker bar cant handle, and if the saft spins put a 4 foot pipe wrench on it, it ant movin
Old 03-30-2008, 08:43 PM
bgilbert's Avatar
Impact on the balancer bolts.
Old 03-31-2008, 01:13 PM
avewilson's Avatar
I used a pipe wrench on the pulley itself, and just an 18" breaker bar on the nuts.
fearlessgordon
04-30-2012 11:34 AM
6.7L MegaCab
30
11-10-2011 10:36 PM
ARIZONACLASSIC
01-27-2010 01:48 PM
Smokin96_12v
10-12-2009 07:39 AM
dieselfuelonly
29
04-22-2007 03:29 PM
Quick Reply: need assistance right now from all that have done the KDP
