need assistance right now from all that have done the KDP
I am at the point of having to remove the 1 7/16" fan clutch nut in order to remove the clutch and fan together as an assembly. Any advise on removing? Everything else wants to spin along with the pulley(I still have the drive belt on). Which way does the wrench turn to remove the clutch fan nut, when standing in front of the truck, facing the engine? Clockwise or counter clockwise? I am deep into this thing, and would like to get it done tonight. Please advise, and thanks in advance.
Clockwise to remove. Take the belt off and use a strap filter wrench to hold the pulley. If you can't loosen it by hand, smack the wrench sharply with a 2 pound hammer.
Got it, and thanks. So now that that booger is done, now the 4 capscrews/bolts that hold the fluid damper(crankshaft pulley) which direction am I turning to remove them? Clockwise as the fan clutch bolt? Please advise.
alwaysonDTR
http://www.pavementsucks.com/forums/...hp?topic=70419
may be this will help it doesn't say there are left hand but check it out again
alwaysonDTR
well when i read down to the part about removeing it, the thread said nothing about those bolts being left hand thread which if they were i would think they would say something about it but it did say they were really tight. i would think they are just normal bolts because of what they are used for and that they have a bolt pattern not one in the canter.
hopefully the KDP master will chime in as soon as he wakes up from his beauty sleep to clear things up. I ended up calling it a night with my breaker bar and socket attached to the capscrew, awaiting direction.
There we go. Thanks for all the assistance, guys. Knew I could count on ya!
For the crank pulley, I had a buddy hold the pulley with a pipe wrench to remove the 4 bolts.
Oh, and have fun with replacing the front main seal! The best part of the whole job
Avery
To get the fan clutch nut off, I had to rent the wrench kit. I had used a air chisel, BFCW (big fricken crescent wrench), vise, anything but the actual tools. Then when I got the tools, I used my weight and a BFH to try and knock it loose. Know what got it off? A section of 3" exhaust pipe that was about 5ft long. In all the hours I spent busting knuckles and saying a few choice words, it came off in 3 mins.
I hope I helped anyone dealing with this problem.
Jon
Jon
