Nasty grinding noise in all shifter positions
Old 07-19-2007, 12:45 AM
12valve@heart's Avatar
200 miles down and so far, so good. Now for the oil, filter, & fuel filter change, some trailer wiring and then hit the road with a load.
Old 07-29-2007, 07:03 PM
10 days and 2225 miles later (with a 35' TT in tow) and the clutch and tranny still seem to be working fine. Currently parked outside DC with another 2 days and 1260 miles to go before arriving back home. Haven't run final calculations yet but getting somewhere around 12mpg towing. If this hasn't broken it in, nothing will. Definitely time for a 3KGS, some new injectors and that HX35/16. Another report when I get back home.
Old 07-29-2007, 07:08 PM
G1625S's Avatar
Been through upstate NY yet? That's my neck of the woods--coffee's on me if you're near Binghamton
Old 07-29-2007, 07:44 PM
Spent most of the week upstate north of Utica in Old Forge but bypassed Binghamton and went thru Albany on the way to Staten Island Friday night. Thanks for the offer for the coffee. All that's left is a 2 day speed run back to OK. Sure did enjoy your upstate weather while I was there. Hate to think about what kind of weather is waiting for me back in OK.
Old 08-02-2007, 09:11 AM
Finished off the trip with 3520 miles on the new clutch and transmission rebuild and both performed as they should. Time will tell whether this 12" clutch will hold up as promised but it handled the 35' travel trailer just fine on this trip.
Old 08-02-2007, 09:34 AM
stwcowboy's Avatar
It's good to see that there is another DTR user close in case of emergency. I live near Stillwater. Let me know if you start outgrowing some parts. I am a new CTD owner, and the 92 I bought is bone stock (as far as I know.)
Lance
Old 10-11-2007, 10:42 PM
Unhappy
Updating an old thread with a new issue.
I now have about 5150 miles on the Getrag, nearly all of them towing a travel trailer and it's still doing well, EXCEPT, I noticed yesterday while taking a rest stop on a drive thru the Texas panhandle that the Getrag is now leaking.
(Builder's tip - high temp gloss black paint on your transmission case looks nice but sure makes finding a leak difficult.)
I determined this morning that the primary leak is coming from between the case and the rear housing (where the shims are). It's also seeping around one of the PTO covers. Yes, the bolts are tight. This made me think back to when I first filled it up and noticed that the other PTO cover was leaking. Since it was still on blocks at that time, I drained it, RTV'd the one cover, and refilled it and it seemed good to go.
I used Permatex #2 non-hardening gasket sealer on all of these locations and now I'm thinking that was a bad choice. My reason for choosing that over RTV was to avoid RTV strings floating around inside and plugging a passage. I've been running Castrol Syntec 5W50 with PowerUp additive in it since it was rebuilt.
Can anyone tell me (assuming that I can keep fluid in this thing long enough to tow a travel trailer 700+ miles from Albuquerque, NM back to east central OK) whether it is even possible to reseal the rear housing w/o pulling the entire transmission?
Does anyone have any good suggestions on how to seal those drips to get me home w/o pouring lots of oil thru it?
Seems like it's never over, is it?
Old 10-12-2007, 02:03 AM
TruckU's Avatar
Can't help on the seal issue, but the shop that rebuilt my Getrag recommended (strongly!!) to put a quart of slick50 in first, then top it off with the 15W40 Delo that I run in the engine. Was rebuilt at 75K, minor issue with loose countershaft bearing at 100K, now at 145K with no issues. Most of my miles are towing, either my boat or a 30' 5th wheel trailer (approx 12K pounds). I get 14-15 towing, and 21-22 hwy running empty (or towing empty boat trailer to Sacremento).
rwhite1
09-01-2012 10:46 AM
Lurch519
02-23-2012 03:44 PM
John_P
NCDTR #18
02-13-2009 03:34 PM
mr T
09-22-2005 09:41 PM
Quick Reply: Nasty grinding noise in all shifter positions
