Mystery tube
Mystery tube
What is the tube that is on the right side of the boost tube on the afc for? It's about a 1 1/2 rubber tube. Mine is dripping a little bit of diesel out of it. Is it just an overflow or what?
1st Generation Admin
It's a vent for the underside of the AFC diaphragm. With time and normal wear, the actual needle that rides the fuel-pin can sometimes leak into that space under the diaphragm (in there with the star-wheel and spring).
Ok, I went through it. Is there a kit you buy because it said something about a "bosch kit" or do I just get the O-ring with those dimensions OR is there a part number for that O-ring?
If you have a good Bosch repair shop around they might give it to you but otherwise you will need to get the kit, it should be under $15.00 or thereabouts.
But..
If you have a Nitrile O-Ring kit and you have the correct size that will also work.
Jim
But..
Jim
Since it is your first time I would go and get the kit from your local Bosch pump repair shop or you can order them online.
Bosch DGK-121 Repair Kit
This is a Bosch repair kit and your dealer would not have a clue what you are talking about.
I would also recommend you build one of these as a precaution.
https://www.dieseltruckresource.com/...y-t297596.html
Jim
Jim
1 Post
If you still in Nampa?
Go here they'll tell were to get it locally if they dont have it.
http://rockymountain.cummins.com/wps...&parentId=3245
But while you got the pump open you may as well put in a 3200 spring.
http://dens-site.net/Dodge_CTD/Gover...ing/index.html
Also get a tophat setup 90% chance you will loose the one you have.
When you reassemble its easier if you remove the power screw just count the rotations. example 15 out 15 in.
1 Post
Hummin Cummins
07-05-2003 09:55 AM
