mystery button???
Old 08-06-2011, 01:24 AM
Aquah0lic's Avatar
mystery button???
I have a small momentary button switch mounted on the dash down near the hood release. I don't know what it's for but since I have a detroit locker and the truck had a gooseneck, I was thinking it could be for a locking converter.
So, is this the type of switch that's used for that? Would the wires go right in where the converter is?
Is there anything else the switch might be for?
Thanks!
Old 08-06-2011, 02:13 AM
Onemoparnut's Avatar
The only way to know what it does is start following the wires. If it was for a converter it would not be momentary. And are trucks dont have locking tc unless someone swapped trannys.
Old 08-06-2011, 02:30 AM
Aquah0lic's Avatar
So you cant put a locking TC in the 518? I didn't realize you had to change transmissions to use one.
Old 08-06-2011, 02:33 AM
Right
Old 08-06-2011, 02:50 AM
Jim Lane's Avatar
Could it be the Valet switch for your alarm system?
Jim
Old 08-06-2011, 10:30 AM
Aquah0lic's Avatar
Jim
Beats me, but that reminds me of another question. I'm assuming the alarm was stock on the LEs right? OK, so how do you turn that freakin thing off? I've never had/wanted an alarm so I keep forgetting and setting it off myself.
I'll just chase the mystery button wires and try to see where they go.
Old 08-06-2011, 10:36 AM
Aquah0lic's Avatar
Right
I thought that goerend TC you have is a locker, no? Why buy one then? Is it just less slippy than a stock?
What kind of trans do you need for a locker?
Sorry for my ignorance, I'm finding the cure a little each day.
Old 08-06-2011, 10:45 AM
An alarm was not factory installed on these trucks. My goerend is not a lock up but it is much much tighter than a stock converter. You have to swap to a 47rh to get lock up and there is a bunch of other things that need changed when you do that swap. You need the engine adapter plate and starter from a second gen plus the drive shaft needs to be shortened usually plus some other things I have forgotten.
Old 08-06-2011, 11:01 AM
BILTIT's Avatar
Do you have dual batteries? My truck had and momentary switch as well and i found it is for a solenoid to connect the second battery for cold starts.
Old 08-06-2011, 12:33 PM
Could be for the Intake Grid heaters if the factory circuit for them is bad or something
Old 08-06-2011, 12:39 PM
lovin1stgens's Avatar
could be a courtesy "thank you" button for towing. someone lets you in you tap the button a few times, makes the running/brake lights blink. kinda hard to say thanks with a wave while towing lol
Old 08-06-2011, 01:56 PM
1st Generation Admin
BC847's Avatar
Nuisance passenger ejection seat?
Old 08-06-2011, 02:24 PM
1STGENFARMBOY's Avatar
Rocket launcher ? ? ?
Old 08-06-2011, 07:01 PM
hotwrench4hire's Avatar
waitress?
Old 08-06-2011, 07:04 PM
Received 1,647 Likes on 1,120 Posts
You guys are funny.
Here I am clicking on "mystery button" thinking that I missed something and all the time it was for the ejection seat on the passenger side.
Now why couldn't I have owned this truck when I was married to my first wife ?
T.
Quick Reply: mystery button???
