my last stupid bed question
As said in my PM the bed itself will bolt right up but the problem you are going to run into is that the dually beds ar cut out quite a bit in the wheel well area. What I believe you will need is to get someone with a dually to measure there opening under the fender to see exactly how big it needs to be and then cut it and get a set of fenders and your on your way. Unless you are planning on going to SRW then forget everything that I just said .
In that case any dodge bed from a 81 to 93 will work just fine for you. Although I dont think that you will need to chang your rear you might be able to get a set of spacers for your rear to get the wheels in the right position to line up with the front wheels.
Where in ohio are you? I have a dually bed that is in desperate need of relocation. Some dents (fixable), no fender, no tailgate. Get it out of my way and it is yours.
