My injector swap....
#46
OK I found one...or I should say I was able to get one loose from the injector. Those suckers are darn near welded on!
Remember these were installed and crushed for sealing....but it appears that the thickness was originally .060". OD is an average of .630 +/- .003. And the ID is an average of .375" +/- .002.
Many thanks for taking the time and trouble to get these measurements.
Now I have something to work with; first, I am going to see what McMaster-CARR has.
#47
I have one of those copper washer kits....I'll go check to see if any of them would work on the 9mm injector.
#48
I am reading along, as a guy that has a few 9 mm injector style motors in the line up.
Thanks Trashing!
Thanks Trashing!
#49
Another oft removed hollow bolt that would also benefit from such an arrangement is the AFC boost-tube banjo fitting.
#51
I open up my pack of replacement copper washers for the 7mm tip motors...ain't no way in that they would work for the 9mm injectors.
#53
Thank you, TCows! Boy, you're on a mission to save these! Good job!
thrashingcows (11-01-2017)
bigwheels94
07-11-2008 03:10 PM
Treangen
63
07-07-2008 07:42 PM
